Had a combie installed in recently. The pressure over the last month has krept down from where it was just above 1psi i think to about half that figure.
I don't know if the leak was from pipework already in the house as we never used the old boiler. It could be from a new bit of flexypipe that was installed to a new radiator.
Is this slow loss of pressure problematic? Should I just top the system up? Or is it worth going under the floor to determine if the joints to the new pipeing/radiator are leaking? Do you think I could see a leak if it is leaking that slowly?
Thank you
Thank you
