Having trouble trying to find the maker/supplier of some very common window roller shutters/blinds that looks very much like the roller shutters on garages & shops, (but more refined). The ones that i have seen are very common in France/Italy/Spain & hotter countries. They can be mounted internally & externally & quite often have the control via an electric motor or via a 2” webbing strap that is often sticking out & then returning into the wall via guides & small rollers in a vertical length of about 2 feet. These straps are often in the window reveal. With these roller blinds, you can quite often pull the strap that you would raze & lower the blind with a small amount to have small light holes/air vents opened or closed if you didn’t want them fully open or shut the unit.
Hope you can help! I have tried the obvious searches for roller blinds/roller shutter but to no avail.
Cheers.
Chris.
Cheers.
Chris.
