- Joined
- 31 Oct 2003
- Messages
- 13
- Reaction score
- 0
- Country
Crackling line ? noisy ? faint transmission ???
dial 17070 if you have ur phone number diasabled from others recieving(number witheld) dial 147017070 , press 3 , press 1 , press 2 (ringback line test) put phone back down and wait a few moments , your phone will ring you back with a test result.
Lines tests ok - this means that the test system does not see any earth , battery or full disconnections faults , but if your line is noisy this can be caused by an HR dis , a slight disconnection that the test system cannot see.
rectified loop - this is more than likeley a faulty extension or sky didgtal box.
battery fault - this means your line is in contact with another line somewhere in the network , if you only have 1 line then this would be in the Bt network.
earth fault - the line is in contact with ground somewhere . 6/10 times this is your extension that causes this, most earth faults are internal.
If you are having problems , then you need to check at BT`s test socket, this is where your 1st socket is from the line coming in from outside, there should be a little front plate (1/3 rd of the socket) undo the 2 screws and pull out this front plate , behind this you will see another phone connection point , put a telephone in here and check if everything is ok , if you are still having problems here or getting bad test results then report this to BT , if everything is ok then it is a problem with something on your side of the network and calling out Bt could leave you with a Callout charge + hourly charge if you require them to repair.
Please note if you have ADSL on your line then the 17070 test will not work on your line .
