I'm helping someone fit a few DG UPVC window units into standard brickwork. We've used two types of fixings to fix the units in, without consistant success.
First we tried some concrete screws - the sort that are supposed to go into masonary without plugs, etc. Sometimes they do up tight, others they just turn but never tighten up.
Also tried some frame fixings, which are unbranded and came from Toolstation - I think. Anyway, we used the right length ones fpr the depth of frames (100mm anchors) and drilled the correct 8mm holes in frame and masonary. They were a little tight going through, so we knocked them through with a hammer. I think that's the correct way? Anyway, first window with these fixing, and although the fixings are all the way in, the screws just keep turning without tightening.
So, which are the best fixings to use, and what are we doing wrong?
Thanks for any help.
