Last week I discovered a 2-way switch connected with 2 core and earth, using the earth as L1... I removed it. Now I've discovered another problem with another switch. I just wanted to replace a few face plates and discover the hazards I've been living with for 3 years! Anyway, this switch is 1-way. It was wall mounted and had a plastic face plate. I have put a metal backbox in the wall and connected a new stainless steel face plate. have put in the earth as it should be etc. When electrics are turned back on, the switch works fine, but when you touch the face plate you get a shock. Have checked all connections several times, nothing seems out of place. Have tried 2 different face plates - same thing. Any ideas? I've put a plastic face plate back on for now and it seems OK, but obviously want to know what's wrong. Thanks...
