HE30 low hw temp
26 Sep 2010
Yorkshire
Hi All,
This is my first post and hope I don`t get flamed for asking for help.
I have a Ideal Isar HE30 (rubbish by all accounts) 3 yr old and its just started to play up.
Central heating side is fine but when I turn on the hot water, it`s only luke warm.
The burner fires up then stops before heating up fully, if I leave the hot tap running it fire`s up again only to stop again.
I have noticed the pressure gauge fluctuating when a hot tap is on.
Any suggestion`s
Thanks in Advance chas
without a second thought blocked plate heat exchanger.
you can take out an clean but you will have to buy new o rings
or you can buy a whole new kit about £125.00 for parts & between £90.00£65.00 labour if you would like a pro to sort it. note these are my fees tho. ;)
