Hi all,
I ma new to the forum and was interested to see if anyone else has an idea on how this can be done...
On the side of our house currently we have 1 fixed window which has a concrete lintle above and below.
We are putting french frames in the other side of the same wall (about 3 metres away from this window, we have ordered the door at 2.4m by 2.1 high.
Great but - - - I have measured where the frame will sit, is it sits on the dame course and measure 2.1 up it hits the middle of the brick so ill have to either put a plastic strip above the french frames or pack underneath - this is only about 1 inch so neither here or there and can be done quite easy but.... this is the problem.
The concrete lintle which will sit above thje french frames on the catnic will not be in line with the original lintle on the other side, so when you look at the house from the patio you will see the 2 headed stones and they will be a course different.
So the options i feel we have...
1., pack the bottom of thje door so the top lintles are in line, this will mean we have a step coming out of the french frames of about a brick and a half?
1. We keep the frame on DPC and we have the top of the french frames and other window out by 1 course. My new french frames will sit 1 course lower than the original window.
My dad says it has to sit in line or it will look really bad, i do not want to have a HUGE step on the french frames and have said tough, i would prefer a small step rather than a big one to get out the house!!
Are there any ways around this?
Cheers all
Mike
Cheers all
Mike
