Hi
I have an off-the-grid self-sustainable-type home. I am currently pressurizing my water mains with a pump from harvested rainwater tanks. Nothing too exotic: when one opens a tap the pressure-drop switches on the pump and water flows.
The issue: since my electricity is from a solar-fed battery array, I don't want the pump switching on and off every time a tap is opened (or the loo flushed) and especially not at night.
The solution: a largish header tank. I'll run the pump to fill it when the sun is shining and I have electricity to spare. Then I'll have water whenever I want it without depleting my batteries.
So far so good.
I'm now just stumped for a rather simple question that, I am sure, a plumber would know the answer to.
How high must the header tank be above the level of the household taps (and the shower-head) in order to have acceptable pressure?
I realize I am asking a "how long is piece of string" type question as there are many, many variables. But assuming:
a single-story house
a header tank on a "tower" (it can be any height, not restricted to being in a loft)
a 1500l size header tank that will usually be more than 50% full (that will increase the pressure, right?)
a 32mm pipe from the header to ground-level feeding the cold mains
a 32mm pipe from the header to the geyser in the roof.
The cold mains and the geyser feed out of the geyser are 22mm.
What is confusing me is that I read on the 'net that decent pressure for a home is considered to be around 3 bar... but you only get about 0.1 bar per meter of head, right? So for 3 bar I need a 30 meter high header!?! That's just silly. But even 1 bar of pressure needs 10 meters. Even this can't be right many city homes use a header in their loft and that's not going to be 10 meters above the upstairs taps.
So I'm a little confused and I hope someone here can point me in the right direction before I buy tanks etc.
So far so good.
