Hi all.
The smaller of the two tanks in the loft has hot water in it and I was always under the impression it should have cold in it. The bigger tank seems to be fine and only contains cold water.
Also should the pipe that goes into the small cylinder be submerged inside the water? I have emptied out the water before so the pipe was clear of the water line but every time i check it the water as risen to cover the pipe.
If this sounds wrong then I need some wisdom
Cheers folks
Crofty
Small tank
View media item 46100
Large Tank
View media item 46101
Cheers folks
Crofty
Small tank
Large Tank
