We have a Rayburn stove fitted into a small 'ingle nook' fireplace. The front of the Rayburn extends (overhangs - the base is 6" above floor level) into the room by 4". The gap between the stove base and the floor was filled with a (non- loadbearing) plinth of cement.
I am laying a woodchip floor, which will have laminate laid on top, and would appreciate advice regarding a suitable hearth.
The original floor was of boards on joists with a large (22"x56") slate slab set in and supported by noggins to be flush with the boards. As the slate is cracked in several places I want to remove this and wondered if I can use an alternative method to fireproof the floor.
Could I simply lay the chipboard up to the wall, re-install the plinth, tile a suitable sized area on top of the floor and lay laminate up to these?
