Hi all,
We have bought a house (3 bed, 30s semi) that has a 10yr old Vaillant combi boiler - it does not have a room/hallway thermostat - just the dial on the front of it.
We chose to leave it on 24/7 at one temp (about 1/3 of the dial) with all the necessary rads on full.
I am going to calculate the usage of the gas soon when I have a few more readings.
We are happy with the temp of the house but given we work daytime hours Mon-Fri I am thinking I should set the timer for 4pm-8am.
But then you read conflicting views that one temp and on 24/7 is more efficient!
Is there a better/proven way to control the heat efficiently? We have good insulation already.
I read one way would be to crank the boiler heat to 100% and control the heat output at the rads - they are just basic valves - no thermostatic ones.
Many thanks for any advice.
Jack
Jack
