Tried chemicals, descaling, powerflushing with chemicals, changed pump (and now up to setting 3), checked mot. valves all to try to stop boiler overheating and cutting off when boiler therm. turned above Min. setting (this occurs very quickly before water has fully heated up). Fan looks OK too. Presume some clogging in Ht Exgr and reduced flow causing problem?? Mild kettling still despite 3 descales. I've neglected it for 18 yrs so it's payback time.
I'm wanting next to clean the HE out (it's sound) on my old Netaheat (MkIIF) but couldn't see a drain plug in its base when heating engineer came round to service it. Just a bolt to secure the wall of combustion chamber on each side. Diagram on Partsarena shows no drain plug but shows two plates bolted on to each side of the HE both with a seal. If these are removed can you gain access to the main chamber to de-gunge it without removing whole thing from boiler? I know re pos. press. /seal dangers thanks to warnings here.
Also how do I identify a bypass in the system? It's an old (20+yrs) open-vented one with two straight zone valves and a pump all in airing cupboard with boiler downstairs. The bathroom rad used to get warm when only hot water on - does this mean it IS the bypass? Last year plumber changed it for a towel ladder rad. and has obviously 'done something' with the pipes - could he have inadvertently altered any bypass arrangement leading to our boiler overheating problems? Have opened rad up fully - no difference.
