Hi, i have a Vizo boiler. It around 7 years old now at guess.
Problem is every 6 months the heat exchanger keeps blocking and the water goes hot and cold. I kept having them replaced but for the last couple of years i have been removing and cleaning every time it blocks. Yes im now doing it myself (the removing and cleaning as got feed up of paying someone to keep putting a new part in), i know i shouldnt be messing myself before anyone says but it doesn't involve opening up the burner section of the boiler. I would never dream of messing in there.
I cant and the other boiler techs i have had in cant work out why it keeps doing it.
It gets blocked up with a black hard like carbon material i have to tap the heat exchanger with a rubber mallet to loosen and remove.
In my battle to combat this issue i have done the following-
2x powerflushes
New radiators
Drain + clean every 12 months
Inhibitor (different brands tried)
Fernox TF1 filter (i clean this out every 3 months and its always full of crap)
The boiler has been relocated after a extension
The house has been rewired (it was suggested that a wiring issue touching pipes might be a cause so when i had extension all electrics was also upgraded)
All extension pipework is plastic, original is copper.
Why does this keep happening the boiler does not loose pressure either? I had considered changing teh boiler to a better brand but will this stop the issue?Is it the boiler causing this?
thanks in advance .
2x powerflushes
New radiators
thanks in advance .
