Would like to know what your thoughts are on aluminium and stainless steel heat exchangers and does this edge on what boiler you tend to install?
I used to install aluminium heat exchanger boilers but after many problems I now only install stainless steel ones. I believe the life span should be longer with stainless steel. Also less problems with artificially softened water being used.
What ever you use must be completely installed and flushed to M I's
All the Giannonis, passageways too small. Just wait 10 years and see if I'm right or wrong. I'm puting a magnaclean on all mine, but there are a massive amount of installers who prefer the extra £100 in their pocket, knowing they can only get so much out of a customer and as much of that belongs in their pocket not in a quality service.
