Im thinking of changing my aging boiler as I’m pretty sure I won’t see another winter out of it. Currently it’s a 26 year old heat only boiler. Just over a year ago I had the whole system upgraded (excluding boiler). It was converted to a sealed system and the controller, room thermostat and diverter valves were replaced too. I had a power flush and I had an unvented hot water cylinder fitted. The pump was replaced by myself about 2 years ago and I replaced 3 radiators so as far as I’m concerned, it’s all in good nick apart from the boiler. My thinking was that when the boiler goes, it’s just a heat only boiler that needs replacing (plus if course a mag filter and condensate drain).
If I get a system boiler, it will include a new pump, pressure valve and expansion tank but I’m thinking just replace boilers like for like as apart from the fact that those parts which I have already are relatively new and anyway, those components are external to the boiler and can be bought cheaper/quicker/anywhere whereas with a system boiler you will need to fit the boiler manufacturer specific parts. Is that thinking correct?
