Hi all
Can anyone confirm if when you convert a heat pump dryer to drainage via a sink, should the drawer still fill up with water?
It's a Bosch heat pump. Been using the drawer for 7 years or so, and recently converted it to use a drain, followed the instructions and have it connected to a mcalpine dual appliance adapter atop a 40mm stand pipe. Removed the little grommet at the bottom of the drawer too.
But it still fills with water ..
