Help please!
I would like to run my transformer-powered Heat Recovery System so that it turns on to full power when I turn on the light switch (via the relay indicated); but it also turns on to trickle when either the PIR or humidistat are activated. The transformer has several voltage settings to control the running rate as can be seen from the diagram.
Please could someone have a look at the diagram in my album and see if the proposal works? My electrician has already melted one transformer and I would like to make sure we have the right wiring diagram before having another go. He is concerned about the two power supplies to the HRS being turned on at the same time with consequences...
