Heated mirror in cabinet door installation
23 Mar 2021
I would like to install a heated mirror pad in a bathroom cabinet door I am building (located in zone 3/unzoned). My electrician has wired up the cabling to a back box behind where the cabinet will go and blanked it off temporarily. The conundrum I have is how to get the cable across to the door without risk of snagging it when the door is opened or closed.
A door loop seems to be the way others do it:
https://images.app.goo.gl/G5NCMvCFkhraEYqu6
G5NCMvCFkhraEYqu6
Since the loop is metal I assume it needs to be earthed. Is that correct?
The house is wired to 18th edition with rcbos on the lighting circuits, from which the mirror wiring has been derived.
