Heated Towel Rail on Primary HW circuit
6 Jan 2008
Sussex
I was considering moving our heated towel rail in the bathroom from the CH to the primary HW circuit, so that we can have it on when the rest of the CH is off, but I read that the Building Regs (Section L) now either discourage or ban this practice. The towel rail is small (three rail Myson) so it's not exactly going to stretch the HW system. What's the true position on this now?
Thanks,
d
Go for it, when would do you expect building control to have a snoop around your piping layout?
Pete
Mine was like that, but I didnt like extra heat in the bathroom in the summer. So now its part of the heating circuit.
mine IS like that, I modified it myself. It has a TRV and the lockshield is throttled down. If I don't want it hot in the summer, guess what I do? ;)
You can add a thermostatic electric element and have both. The problem with the HW circuit is that today's cylinders do not require as many heating cycles so most of the time the cyl stat is satisfied and your towel rail cools.
Are but mine is the rad without the trv ;)
Thanks to you all for your replies, especially Nixt - you have saved me from making a time-consuming mistake: it hadn't occurred to me that when the HW cylinder stat is satisfied there would be no circulation in the towel rail - although it's obvious to me now! I'm going to leave it on the CH system and just turn off the other rads when we want the towel rail on. :D
mine come off between the pump and the three-port valve so it gets the best of both worlds. Hence the throttled-down lockshield to prevent it stealing flow.
