Hope someone can shed some light on the following,
At the moment I have a 600 x 1450 flat white towel rail in my en-suite with 19mm tubes. The towel rail has bars placed as follows reading from top to bottom 2-3-13-3-14. A friend has said he thinks it is probably rated at 1kW. It also has an electric element although this is hardly ever used.
The en-suite is H 2.4m W 1.5m L 3.0m, it is tiled on all walls and the floor and has two outside walls. There a 650x1000mm A rated UPVC window and it has an open aspect to fields on the window side.
During the last two cold winters the towel rail has struggled to heat the room effectively, the maximum temperature reached being 19C although most days it was slightly lower than this. I should mention that the room is the furthest away from my boiler and therefore takes time to get to it's full working temperature.
I have been thinking of fitting a small radiator in the room to boost the heat during cold weather but after some browsing have begun to wonder if fitting a replacement towel rail (curved) with 22mm tubes would give sufficient heat boost to get the room up to the normal suggested temperature for a bathroom of 21C or higher. This would be a much cheaper option.
I can't go for anything wider but could just about fit a slightly higher unit.
I have searched without success to find a way of working out how much heat my current towel rail produces.
I have seen some towel rails where the actual rail(s) for holding the towels is curved away from the main body and this would be my ideal however a standard curved towel rail would be OK.
Any advice much appreciated.
