Has anyone got tips for heating in a conservatory, prefer not a halogen heater as we have children. Found underfloor heating expensive as its 3m by 4m floor area, may consider a radiator to add if possible.
Dimplex make a wall mounted fan heater, with thermostatic control and timer. I've fitted a few of these in conservatorys. About 200 quid.
Or if possible you can run pipework from central heating and install a fan assisted radiator. Normal convector radiators aren't good enough, because they can't keep up with the heat loss in a conservatory...
