Heater in cupboard to dry clothes
29 Oct 2024
Hi, during the winter times we are finding that we are running out of space near radiators to dry our clothes on airers. I have thought of buying a heated airer to speed the drying up but we don’t have much space. So I was thinking, we have a larger cupboard in our utility room and I was wondering if I could build some rails to hang the clothes and fit an electric heater. Any thoughts on whether this is possible?
I would probably want to close the door of the cupboard so keep as much heat in as possible so would I need some ventilation?
Advise on heaters would be appreciated .
Thanks in advanced
Thank you for getting back to me so quickly. Would I be able to put the dehumidifier in the cupboard?
You will need a some air circulation to prevent the dehumidifier overheating but far safer than a heater. I use one in my kitchen and a full load of washing dries in about 5 - 6 hours. They are not expensive to run.
Dont put a dehumidifier in a cupboard. It needs good airflow to be safe and efficient.
Drying clothes, on or near a rad, is a tremendously bad idea, Trying to dry in an enclosed space, an even worse idea. If you must dry indoors, then a small room, with a dehumidifier running in it, and a small fan, works well.
In our old house, we used to have a cupboard at the top of the stairs with slatted shelves. More of an airing cupboard than a drier though The door had vents in it, top and bottom to aid air flow. Worked fine. The heater was a tube heater fitted on the floor. Do a search for 'tube heaters' but you can’t beat a heated rail for indoor drying.
