Hi All,
Could sure use some help with a little heating / cost problem.
The house has gas central heating, a conventional system with a 40k btu boiler and radiators of about 25k btu / 6.3kw + h/water cyl.
I have a small room containing some delicate plants which must be kept at no lower that 15deg C - day and night.
Normally the central heating would be off at night and when out at work.
It would be too expensive to keep all the central heating on all the time, and have been using an electric fan heater to cover the times when the main heating is off.
However this is proving expensive in this colder winter so I wondered is I could use the central heating instead.
Thought about laying in a separate valve, pipes and thermostat for just this one room; ( not too difficult )
However would this cause too much strain on the boiler as I would have thought it would cause a lot of cycling ?
From my simple obersvations / calculations, the electric way needs about 750w per hour, worst case, which costs about 10p a hour.
Gas costs seem a bit hard to establish but running the whole gas central heating for 1 hour, say when getting in, uses .55 units on the gas meter or about 3p per hour for the whole 6.3kw, which seems a much better value if my figures are correct ?
thanks
Ricky678
thanks
Ricky678
