Heating Advice
18 Oct 2009
Hampshire
Hello
I have had a shiny new boiler installed its a Worcester bosch greenstar 25si compact comb.
Ive bought a Nest thermostat thing im just waiting for my sparky to fit it.
At the moment its not too cold outside but once or twice last month it went below -2. I just happended to go around and touch all the radiators. All of them are luke warm, I have bleed them but they remind the same.
My water pressure reads at 1 bar
The Right hand side dial with a picture of a tap is at 50c
The radiator dial on the left hand dial is currently on 40c.
I have a cheap thermometer it is showing room temp at 21C
Shouldn't the radiators be hot to touch?
Im not cold at the moment though.
Ask your installer who fitted the boiler if it is correctly set up as per installer's design.
You could turn up boiler radiator temperature up. But it may make rooms uncomfy too warm.
Daniel.
