- Joined
- 3 Apr 2004
- Messages
- 116
- Reaction score
- 0
- Country
I have just moved into a house with a Thorn Apollo boiler and the gas pressure valve has been changed recently as well as hi and lo stats and the pump replaced in 2001.
My problem is, when its switched to hot water only, the radiators are on and the pump is on all the time, if I switch to water and central heating nothing changes and if I turn up the thermostat nothing happens.
Any ideas, it has a switch in the airing cupboard part no. HSA3 that looks like its supposed to switch between the two, could this be faulty?
Also I want to replace the honeywell thermostat with a Drayton Digistat 1
The honeywell is wired as
red = 1
yellow = 3
blue = 2
The digistat requires
1 to be common
2 to be satisfied
3 to be demand
How do I work out which wire is which? I guess red is common.
Any help appreciated.
Chris
red = 1
yellow = 3
blue = 2
1 to be common
2 to be satisfied
3 to be demand
Chris
