gas4you said:
Usually near the hot water cylinder in the airing cupboard.
Cheers. Is it true there should be a summer value that can be switched off during summer - or someone pulling my leg?
Previous posts - anyone shed any light:
********'Check operation of electrical switch (black plastic housing) on side of diverter valve (bottom right front corner of appliance). If arm is not moving far enough to activate switch, adjustment can be altered.'???
********'cylinder stat faulty' ???
********'You will have a rotating valve on the CH side, very possibly on the HW side as well, although this need not be so.
The valve is driven by an Actuator ( small electric motor ) which rotates the valve to both switch on the CH and open the CH valve. I suspect the Actuator has stopped working or the valve has stuck - or too tight to move (should be possible to rotate with fingers), and when the HW 'sensor' switches 'on' to heat the tank, as the CH valve is also open the water will also travel to the radiators.
Look for a box with a cable sitting on the pipework which will be sitting over the valve.
Disconnect - you can leave the valve in closed position (turn across pipework with fingers if the valve is OK) - and take the Actuator to replace. ' ???
emirates?????????
oh that team that just scraped into top 4 - now i get you.
