heating comes on with hot water
8 Jun 2008
Hampshire
hi,
i have a potterton flamingo 40 boiler,with a randall 4033 switch, my problems is that none of the timings are now working so to have hot water the heating comes on as well. the valve i have is a danfoss 2port HPA2 would this cause the problem?? i moved the arm to manual very slight resistance but it wont go back now!!!
any ideas will be greatly received
thanks
there should be 2 * 2-ports, the heating one is probably letting by - new valve reqd.
Mick, thanks for the quick reply just to confirm what i think you meant?
are you saying that there is probably two valves??
one is next to my tank ..........the other would be ??? (not so obvious) :cry:
thanks
Some older systems only had a 2 port for heating and just let the water pump through the HW circuit whenever the boiler was on.
some even had manual valves to close of the heating circuit !
