Hello,
Please can help. I have the following heating system:
Potterton Prima 30e boiler
Honeywell room thermostat
Honeywell ST6400C Heating / Hot water control, and timer.
It works fine if I have just the hot water, or the heating switched on. However, when I switched switched the central heating on today in addition to the hot water - which was already on, the heating control switches itself off.
I have tried each independently, and they both work fine, and I have also adjusted the thermostat, and that appears to be working.
Could it be the motorised valve that needs replacing, if so would you recommend I stick to Honeywell parts, or do you know of an alternative brand just as good. Thanking you for your assistance.
