- Joined
- 17 Jan 2024
- Messages
- 3
- Reaction score
- 0
- Country
I have an unvented central heating system, there are a couple of problems.
The PRV on the cold water inlet is slightly leaking, the water leaking is cold.
The boiler is under warranty and we have an engineer scheduled to arrive next Weds to resolve the cold PRV water leak.
The system has 2 x 2port motorised valves, I have checked both valves and the mechanical valves open and close and both motors are working when the respective thermostat closes them.
The pressure gauge by the water tank is reading 1.5 bar and the boiler read out is 1.7 bar, the radiators have all been bled in the last 24 hours. I have already replaced the hot water valve motor head as this appeared to be the initial issue.
However, when the hot water is heating up the central heating is on, although the radiators aren’t particularly warm.
When the hot water gets to the set tank thermostat temperature the hot water 2 port valve closes and the boiler stops, even if the heating thermostat is still calling for water and the heating valve is still open.
I have tested it by disconnecting the motor head from the hot water valve and physically closed the valve, in the above scenario the boiler remains on and the radiators warm until the room thermostat reaches temp and closes the heating valve.
Is the hot water/heating on off issue likely to be resolved by the PRV issue being fixed? If not any ideas as to what the issue is, the boiler warranty repair won’t cover anything that isn’t directly involved with the boiler. But we don’t want to get an independent engineer out and find the “free” warranty repair would have solved it.
Any ideas or thoughts greatly appreciated
