I am having a new cupboard built round the hot water tank and want to move/tidy up the electrics as part of this process.
I currently have a set up as follows:
Power:
- Spur from Ring with a Double Socket (surface socket)
Plugs wanting to use this double socket:
- HW Tank Immersion
- Shower Pump
- HW/Heating Programmer
The plug from the HW/Heating Programmer comes from a junction box (connections made using a choc block inside a single surface box with blank faceplate). This then branches to the programmer, thermostat, boiler & pump.
All cables are surface mounted.
What is the best way to tidy this up?
Should I change the spur into the ring? Presumably this can be done by breaking the ring and adding a further cable to extend.
I would prefer to have switched spurs. Can these be within the ring?
Any other thoughts?
Many thanks.
Power:
- HW Tank Immersion
- Shower Pump
Any other thoughts?
Many thanks.
