Just recently hot water has become very cold to lukewarm. Remembered similar problem 2 years ago which was diagnosed as the motorised 2-port valve.
Tried manually switching valve into manual from auto and this seemed to cure the problem however it seems a little intermittent.
Replaced the valve motor on the honeywell but once again this has not cured the problem. Get plenty of water out of the hot tap but its just not that hot.
Could the problem be the valve itself or could it be a stuck thermostat ?
I have a Drayton Tapstat cylinder controller on the hot tank.
Can anyone advise ?
Can anyone advise ?
