I've lurked about the forum looking for an answer to this but anything I've tried doesn't seemed to have helped, so I thought I'd register and ask.
I few weeks ago I got a dscaler and added it to my central heating system. The system is vented and has a pump. I drained enough water to get the dcsaler in, refilled the system, bled the radiators and turned it all on. the boiler fired correctly, worked for a number of minutes, then shut itself off. Water came out of the overflow before the boiler went off, suggesting the water woesn't circulating. I left the pump going in any case to try to get the solution moving. It wasn't cold so I left the solution in for a few days and drained the system. Water came out (nice and black) and I drained the entire lot, refilled, bled and switched on.
Again the boiler fired and ran for a few minutes before the overflow started pumping and the boiler went off. The only thing I could think of was a blockage somewhere or a malfunctioning pump. So I closed the valves on all the radiators bar one. Same problem. I drained the system and checked the return was empty (the pump is on the return by the way at least as far as I can make out). It was. I removed the pump and forced water through it at high pressure to clean it out. Reconnected, refilled, rebled, restarted... exactly the same thing. The pump is definitely working and switching the speed on it makes a noticeable noise difference. So now I am stumped.
The only other thing I will say is that the downstairs radiators were not heating correctly before I introduced the descaler (hence the reason). When I bleed the system dry those same three radiatiors refuse to empty even a little. I presume they are sludged up and I'll have to empty them manually - however I also presume that cannot be the cause of my trouble or the system would not actually have emptied.
Should I leave the system running for a few hours? Once the boiler cools a little it'll refire and I'll get the knocking again. The thing that is worrying me is that the flow is piping hot but the return appears cold to touch (tested at the boiler).
Please - any ideas would be welcome at this stage.
p.s. I'm quite new to this sort of thing but learning rapidly as I go along.
