Hi people. I hope you can help me.
We have an old primatic heating system. Gravity fed for the hot water and pumped for the Central heating.
The problem is that the radiators still get hot when only hot water is selected on the timer.
It seems they are being heated simply by convection as they still heat even with the water pump disconnected. If I close the manual valve on the pump then the radiators don't get hot, but this is a pain having to do this.
My question is, can I just fit a 2 port valve in place of the manual valve?
If so how is it wired, do I just wire to the same terminals as the CH pump, so they both activate together when the CH is selected to come on?
Also is it normal for this to happen with gravity systems? I know the pump is on it's way out as it doesn't heat the downstairs radiator unless I turn the upstairs ones off. It just seems odd that the radiators get hot upstairs without being pumped.
Your help is much appreciated.
