Got a few queries - and hoping for some help:
1. Cast iron period radiators, with period style Gothic Thermostatic valves - possibly made by Bentley or similar - like this http://www.hotinteriors.co.uk/produ...rv-thermostatic-radiator-valve-antique-brass0
Almost all are faulty or weeping - sticking despite me regularly freeing them off. Can I replace just the glands? Can't find any relevant spares, but wondering if there were any kind of standard? The valves range from £60 each and up to replace, and I have 10 rads with this type of valve (16 rads total). They look pretty, but seem unreliable, which leads me to my second question.
2. I thought about replacing them with Honeywell VT200E's (and painting the white plastic Bronze), such that I had a modern design decent valve that didn't look too odd on a Cast Iron rad (missus is not keen on my plan). Does anyone else make a Brass TRV around the £20 mark that is of a good functional design?
3. Combi Boiler is Vokera Linea 36HE with 411 Wireless Programmer Stat. It doesn't seem to be cutting off when programmed off - and instead runs continuously. I have a hunch that this might have coincided with me installing a wifi extender in the house, so will try some diagnostics with and without that on this weekend when I'm home. If that proves unsuccessful, is there a common boiler fault that would give this symptom on this model? Occasionally (once a month?), I have to reset the boiler as I lose heat to the rads although everything seems to function normally otherwise.
4. I've tried balancing the Rads, but using an Infrared thermostat, I don't get anywhere near a 12C drop across them - more like 3-4 degrees max. Flow rate too high or is this a feature of a cast iron radiator?
5. Lastly, the furthest Rad from the boiler gets plenty hot with the TRV wide open and lockshield wide open, but the room struggles to get up to 19C or so - I suspect the Rad is undersized, but wanted to check my logic.
Sorry for all the questions - I though I'd start by sorting out the TRVs first, as they are the most annoying problem, but trying to save some money by sorting out any obvious problems.
Appreciate any help from kindly engineers who frequent these forums!
Simon
Simon
