Hi, I am in the process of changing my kitchen around and have removed two radiators which are no longer needed. Prior to removing the radiators I drained the system as I wanted to cut the pipes shorter and hide them out of the way. I put stop ends on the end of the cut pipes and refilled the system. I filled and bled the radiators and tried to bleed the pump but no air came out. I have since turned on the heating system but the boiler is not firing up and I don't know what to do next.
The heating system is "open" type, the pump is running but getting hot so I turned it off.
Do I need to join the cut pipes together to ensure the water flows through the system?
Should I force cold water into the system to try to remove a blockage?, if so what would be the best point to start? is it better to repeat at several places?
Thanks Nick
Thanks Nick
