Hi
I've got a Portterton (Supreme1?) boiler, and a basic thermostat in the living room. I had a Potterton EP2002 heating control in the kitchen (where the boiler is). I had to replace the control because the slide switches (for timed, constant, once etc) had been broken and the metal contacts inside weren't making contact. So, I replaced that with the EP3002 which is compatible.
Now, when the timer kicks in, the lights illuminate for CH and HW, but the boiler doesn't always kick in. Sometimes I will set the time for e.g. 5 minutes time, and wait. When 5 mins is up, the lights come on, and maybe 30 seconds later, I will see the boiler fire up. But, like this morning, I'll wake up to a freezing cold house, even though the lights on the control panel are illuminated.
I have noticed that if I move the thermostat to a low temperature, wait a few seconds, then move it past about 20 degrees, there is an audible click. Then I hear the boiler firing up in the kitchen. So my first guess is that the thermostat isn't working quite right.
Also, when the boiler is working, there is a fair bit of churning in the radiators, so I think they are full of air... (I seem to have to bleed them once a week...).
Finally, even when the heating is on constantly, the radiators may be very hot for perhaps an hour, but after that they go cold again for the rest of the evening, unless I manually intervene.
Would appreciate any help. I'm not qualified and only have basic knowledge of CH, so I want to try and understand the problem before I get an engineer out which may cost a lot!
Cheers
Cheers
