I have a Glowworm Ultimate 80FF boiler providing hot water and central heating (more than 15 years believe). Cold water tank in attic. hot cylinder (CYL) in airing cupboard with 3 port divertor valve (VALVE), drayton control programmer (PRG) and grundfos alpha pump(PUMP) fitted as well. Recently heating doesnt come on even when initiated by PRG and room stat (ROOMSTAT). It did come on if HW is selected on PRG. Now even that alternative is not working properly with requirement to increase cylinder thermostat (CYLSTAT) manually, which is troubling because unless hot water is utilised, heating will not come up again.
Additional notes
1. It seemed indicator on VALVE wasnt moving till few days back. It started moving after I switched off the power to control box in airing cupboard. It makes a clicking sound oscilating 2 degrees when both CH and HW are selected after power up. It gets stuck on right (CH) selection if CH is selected only on PRG even once and doesnt go back to HW setting, or middle oscilating setting unless power is switched off to PRG.
2. PUMP only comes on when CYLSTAT is increased and shuts off when it appears CYLSTAT is satisfied by boiler.
3. Opened ROOMSTAT (honeywell 6830 believe) and seems to give correct signalling on selection.
4. Heating (radiators dont heat up) doesnt come on even when both HW and CH are ON in PRG
and ROOMSTAT turned to 30 (and ROOMSTAT giving audible click at 15)
my initial belief was that either the divertor valve VALVE (drayton bgmvsp-23) motor or the actual 3 way valve under it is faulty. Both of these will require draining which seems too much to take on. But the recent development with PUMP makes me wonder if its something to do with electrics.
Need help to diagnose the issue and faulty part in the system.. Urgent help appreciated as kid under 2 years old
Additional notes
