This strikes me as being a bit odd, but I'm guessing the 3port valve is to blame.
I have just fitted a new salus SBMV32. It is all wired up as per the instructions;
Blue - Neutral
White - HTG Call
Orange - HW Call
Grey - HW Sat
Yellow / Green - Earth
All appeared to be fine, the heating fired when the room stat called for heat, so I assumed all was well.. However I have just noticed that the heating will only fire the boiler when the tank stat is on (ie calling for more HW).
Is this down to a faulty micro-switch on the valve, or have I made a balls up of the wiring somewhere ?
Water is working as it should..
Cheers!
Blue - Neutral
White - HTG Call
Orange - HW Call
Grey - HW Sat
Cheers!
