My C.H system is open-vented type. A pipe-run in the concrete ground floor is leaking slightly, the floor surface is wet. From tying-up the ball-valve and measuring the drop in water level over two days, I worked out it has lost about 8 litres in 48 hours. Is there a possibility, that Fernox leak-sealer may seal this? I have not used it before. Any advice would be much appreciated, thank-you.
