In our extension, I am trying to decide the best way to run the ch piping. Where I have to take the piping across the new doorway, I had originally planned to take it up in a stud wall, across inside the ceiling void and then back down the wall (surface mounted) to the radiator.
Now I'm wondering if it would be better/more efficient to cut a channel in the 100mm conc slab just inside the doorway - much less pipework.
Question is, how big to make the channel? Big enough for fully lagged pipes with say 15mm concrete back on top (ie about 70wide x 50 deep), or just big enough for some hairy lagging wrap (ie about 45wide x 35 deep). Will the heating/cooling cause problems with quarry tiles laid on the concrete?
Any thoughts?
Any thoughts?
