I'm thinking of running some heating pipes in my extension in 15mm Speedfit, is this a good idea? What are the pros and cons. Need to run through joists so seems the obvious answer, otherwise I'd need joints in the copper between almost every joint. What would they have done pre-plastic? (Notching I suppose.) Are there any regs regarding this?
Also I am going to run some down the inside (obviously) of an external wall behind the dot and dab, should I consider lagging them?
Much appreciated
Much appreciated
