HI guys,
Have a Suprima L boiler which is causing me grief at the moment. Comes on in the morning as timed with no problem to heat rads. Seems to turn itself off after about 45mins (presumably has reached temperature) even though heating has not reached setting on room thermostat. Rads then cool down as boiler red light is on and getting no call for heat. Boiler will only come back on if we use hot water. Have recently had diverter valve replaced so don't think it is that.
This is a very intermittent problem as it comes on and off as is should do in the evening.
Any ideas ?
Any ideas ?
