heating problem
2 Sep 2010
Liverpool
can anyone work this out. on a two port central heating system when hot water only is switched on the return pipes to the radiators heat up.both motorised valves have been replaced and are working fine.have bled all air out of system.any suggestions would be appreciated.
Sounds like reverse circulation on the return. Where is the return common connection? It should be as close to the boiler as possible.
Three replies within 10 minutes but the OP has not replied yet!
sorry for the delay new to this.the problem has only started this year when i tried the central heating in readiness for the winter.
