Hi
I'm replacing all my UFH manifolds and controls and it entails moving all the pumps and pipework around. I want to connect a central heating pump (1 1/2" bsp I believe) to a Mixer valve which has a 1" Bsp connector.
I don't reall want to put on a pump valve to 22mm compression, to a bit of 22mm pipe to a 22mm / 1" connector on the valve. It will work but the whole assembly will be a bit long.
I've googled away but can't seem to find if there is a suitable connector where I can screw in a 1 1/2" thread on end and a 1" the other. Any ideas?
