I have installed a worcesterbosch 24CDi/28CDi RSF
The system is excellent but I have been advised to have all of my radiators on at the same time and set at a minimum of setting 3 as this maintains the pressure. Now I have turned off radiators in rooms where I require no heat as I believe this is costing an uncessary expense but the pressure drops to zero. Should I keep all the heaters on as advised and is it costing me more using them all?
I noted the pressure rose to almost 1 when all the radiators were on but I have now turned only 3 of the 6 radiators on and the pressure is just above zero. What should I do?
Alan
Alan
