Hi
I hope someone can help
I have a heating issue,everything was workign fine, and suddenly stopped.
i have hot water running, and works fine, but my rads are gettign no heat.
I replaced the pump and fired up the boiler, then the boiler cuts out, and pump cuts out, and i get no heat to the rads.
If i put rads and hot water on from the programmer, the pump starts to work, but i still get no heat to the rads.
Any idea what could be the problem? i thought the pump wasnt able to push, but was replaced but no noy.
could it be the programmer? or the port valve? the port valve does move when hot water is switched on.
i would be grateful if someone could give me some advice.
thanks in advance
Rav
thanks in advance
Rav
