Hi i have a heating system with a small header tank in the loft i recently had a leak in by the pump wich was reparied by british gas but the system failed to refill they advised me that i have some blocked pipes in loft and the air seperator is blocked they quoted me £785.00 to replace blocked pipe work remove air seperator and power flush the system .
i am quite able to remove and replace the pipes my self but i am not sure about removing the air seperator as it is currently piped as this 15mm inlet from header tank 22mm vent pipe to header tank 22mm pipe top pump 22mm pipe from boiler.
if i do away with the air seperator how is the pipe work configured
is it possible to clean out the air seperator
do i need an air seperator
also would it be advisable to flush the system when the pipes are replaced
some advise on this would be appreciated
regards
regards
