Heating thermostat & timer changed but does not do what
18 Jan 2007
Nottinghamshire
Hi guys more help needed.
Right then
Originally there was a thermostat and a timer like this one
http://www.screwfix.com/prods/89388...ers/Mechanical-Immersion-Timer-24-Hour;jsessi
Now then after, a discussion was reccomended this baby
http://www.awin1.com/awclick.php?aw...ating-Controls/Horstmann-DRT2-Room-Thermostat
Unfortunately this is a bag o sh1te as it does not do;
1 Individual programs for each day
2 Does not have a BOOST or Overide facility
They want to be able to press a button to turn the heating on until the next period or turn it on then off
3 It does have a temp. overide which they like
I have been looking, I have seen this little baby
http://www.screwfix.com/prods/88114/Plumbing/Central-Heating-Controls/Danfoss-TS715si-Timeswitch#
however the wiring diagram has me confused
Am i right in thinking that I just connect L, N, E(in parking point) to this and the pin rail thing picks up for the contacts.
Can some one please please please tell me if this is what I want and are my assumptions correct about the pin rail thing!!!
Much appreciated
Are you just wanting a straight time switch, or do you want something with a thermostat built in as well?
What wiring do you have at the existing point? Is there a three core & earth there?
Hi rob
Needs to be timer and thermo.
Presently there is, wait for it......
a live feed running through fish key switch, a neutral, an earth and a black wire with brown tape on it that I am assuming is the live back to the heating!!!
(It is a right knock up job!!!!!!) not by me mind!!!!!!!!!!!!!!!!!
the neutral is not currently in use ?????
The danfoss you linked to is just a straight programmer. It's not a stat.
You want something more like this.
It seems to have the functions you need.
You just connect the permanent live and switched live to the unit.
It does not require a neutral.
WTF is the key switch for? Sounds like rather a strange setup.
Cheers Rob
So this will definitely
1. allow them to give individual programs for each day of the week?
2. Boost/ overide the timer when they want to?
3. allow them to overide the temperature?
The fish key switch!! FOK!! But they do like the sound of the 'big metal box clanking' as you turn the load on and off using it.
If it keeps them happy then it is fine by me, as far as I can tell it is purely there to let anyone run the back-up batteries down!!!!!
Thanks for your help 'Oh Great One'
Going to ELEX per chance? Free bacon butty and T-Shirt!!!!!
Hmmm, it doesn't appear to have an advance facility, but the temperature can be over-ridden.
I'm wondering if you might be better geting a standard programmer and a manual room stat, and connecting them together.
Not sure about ELEX. I think I'll struggle to blag yet another day off work. :LOL:
It must have the advance / boost thing for heating, they're very clear on that.
Recommend something mate, I'm loosing the will!!!! Something that does both or if not programmer and thermo will have to do
I did mention this is only for the heating, didn't I?
