Hi all,
After some of your expertise, my central heating is working great except for when it is turned on water only at the clock heating comes on too, I'm sure it is a wiring issue as all was fine until I had a new pump and mid valve fitted, the friend of a friend Recommend fitting a Honeywell wiring centre to tidy up connections because they were on block connectors and did look unsightly not to mention a little dangerous, anyway since then house is boiling until the cylinder sat is satisfied. All wire are in the correct positions wondering if there needs to be a link wire? Programmer is a danfuss 102 water only and water and heating switch, premaflow pump and a Honeywell v4073a diverted valve.
Any help appreciated
A sweaty 779 dave
Cheers
A sweaty 779 dave
Cheers
