Heating won't go above 50 degreas
1 Nov 2009
Tyne and Wear
Hi can anyone help, I have a Baxi 105e boiler and the central heating side will not go above 50 degrees. A new diverter valve was fitted recently and is working fine. all radiators are warm and there is no air in the system. the pressure gauge on the boiler is holding at 2 bar.
Do you mean the room temperature, or the boiler temperature?
If the room temperature, do you have a room thermostat?
How long has it been like this?
Did it suddenly get this way or has it become gradually worse?
Why was the diverter changed?
Does the dhw work properly?
I mean boiler temp, The diverter was changed because there was no dhw but after change over dhw fine now
Lots of reasons
A few obscure things worth checking
1. The micro switches are on the right pins
2. The NTC sensors wired up incorrectly (HW on CH and visa versa)
3.The PCB (if removed) refitted with potentiometer 180° out
The prolem started after the diverter valve was fitted. All the micro switches and sensors are back in the right place. The PCB was not removed
A simple DIY check is to see if all the valves under the boiler are fully open.
A bit more advanced is to remove and clean the CH filter which should be in the return valve but is often on the flow instead.
Tony
as baxpoti said.... has the PCB been out since the problem started????? even more obscure, did the control knobs come out???
